Williams FW42, Silverstone 2019 / R.Blaschke / 1:24
MatesHK
Re: Williams FW42, Silverstone 2019, 1/24
Příspěvek od MatesHK »
Pěkná práce Míšo... Tak ať se brzo vrátíš a všechno dobře dopadne ;)
Já už mám taky vytištěno (pro jistotu 2x) i s podlahou tak můžu pokračovat ;)
mary
Příspěvek od mary »
Ahoj, Roberte.
Nevím zda mohu vznést malinkou připomínku.
Musel jsem poodstřihnout díl, který nepasoval na protikus. Na výkrese je i patrný rozměrový rozdíl.
Modeláři si s tím poradí. Já jen, kdyby jsi to chtěl poopravit. Proto ta alfa.
Robert Blaschke
Okey, ja som tam tiež trošku pristrihol ten oblúk na prednej časti, aby to lepšie sadlo.
McClane
Příspěvek od McClane »
Hey Guys, I really like what I see here and makes me wish to start the model myself! Unfortunately there are other projects to continue first.
However, would anyone of you be so kind and tell me which paper quality works best for this model? I know, this is something that was likely asked a thousand times, and also some information is included in the drawings (like what cardboard to use). Still, it would be great to have information like (I know, these examples probably make no sense at all)
- to use 160 g matte or semi-glossy paper for matte parts
- and use 120 g glossy paper for glossy body parts + carbon.
And if you are going to scale the model to e.g. 1/43
- to use 120 g matte or semi-glossy paper for matte parts
- to use 90 g glossy paper for glossy body parts + carbon.
Or, if you are using glossy finish, just use 120 g matte or semi-glossy paper for all sheets.
Something like this. And I would really welcome if such information, at least for the original scale, would be included in the drawings ;)
Last but not least, congratulations to all who have showed their models until now, and more importantly thank you very much Robert for your amazing free F1 models!!
I dared to translate it into the Czech:
Ahoj lidi, velmi se mi líbí to, co zde vidím, a vybízí mě to abych sám začal se stavbou modelu! Naneštěstí existují i další projekty, které chci dokončit dříve.
Byl by však někdo z vás tak laskavý a řekl by mi, jaký papír pro tento model nejlépe použít? Vím, že to je něco, co bylo pravděpodobně dotazováno tisíckrát, a také jsou některé informace obsaženy ve výkresech (jako např. jaký karton použít). Přesto by bylo skvělé mít informace jako (já vím, tyto příklady pravděpodobně vůbec nedávají smysl)
- použijte matný nebo pololesklý papír pro matné části
- a použijte lesklý papír 120 g pro lesklé části modelu + uhlík.
A pokud se chystáte model přizpůsobit do měřítka např. 1/43
- pro matné části použijte 120 g matný nebo pololesklý papír
- použijte lesklý papír 90 g pro lesklé části těla + uhlík.
Nebo pokud používáte lesklý povrch (lakování?), použijte pro všechny listy 120 g matný nebo pololesklý papír. Něco takového. A opravdu bych uvítal, kdyby takové informace, alespoň pro původní měřítko, byly zahrnuty do výkresů :wink:
V neposlední řadě blahopřeji všem, kteří doposud prezentovali své modely, a co je důležitější, děkuji Robertovi za úžasné modely F1 !!
Dovolil jsem si rychný překlad
old_Mr_Grim
mary
Příspěvek od mary »
To jsem rád, Roberte, že se mě to nezdálo. Jinak skvostná konstrukce novodobého vozu.
Když to vidím, tak se mě už nechce jít do toho Ferrari. Nemá smysl dělat něco horšího než existuje.
Nechceš ho postavit za mě.
MatesHK
HURÁ :) podlaha č. 2 je hotová...
St. Louis
Příspěvek od St. Louis »
MatesHK: Druhý pokus taky super. :D
A míša kulička to rozjel ve velkém stylu. To byl fofr. Paráda.
Všichni to máte moc pěkné a je bezvadné, že je nás už tolik co staví. 8-)
(Snad se k lepení konečně o víkendu dostanu. :roll: )
Co se týče papíru, tak vycházím z toho co napsal Robert v prvním příspěvku
Robert Blaschke píše:A urobím to opäť ako aj s Force Indiou z roku 2017...
a tehdy byl doporučen papír 120g.
Mějte se krásně. Ahoj.
mary
Příspěvek od mary »
Pokusil jsem se model slepit z lesklého fotopapíru, ale bohužel se na titěrných místech loupe vrstvení.
Takže začínám znovu z klasického Color Copy 120gr laserový tisk.
Vůbec se mi nelíbí moje napojení komínu, tak jsem si obě části slepil před zpracováním,
a jako to bude vypadat teprve uvidím.
McClane
Thank you @old_Mr_Grim for providing the translation! And sorry for not providing it myself. But I will do it now, though by using Google Translator which may end up in a mess, but we'll see! ;)
@St. Louis thank you for the hint! Will have a look there too ;)
@mary thank you for confirmation of 120g color copy paper ;)
---- CZ below ----
Děkuji @old_Mr_Grim za poskytnutí překladu! A omlouvám se, že jsem to neposkytl sám. Ale udělám to hned, ale pomocí Google Translator, který může skončit v nepořádku, ale uvidíme! ;)
@Svatý. Louis děkuji za nápovědu! Bude se tam také dívat;)
@mary děkuji za potvrzení 120g barevného kopírovacího papíru;)
Robert Blaschke
Pridávam ďalšiu sekciu - tentokrát iba na pol stránky - bočnice a prevodovku:
http://modely.blaschke.sk/42-sgb.pdf" onclick="window.open(this.href);return false;
Tým je v podstate ukončený hlavný tvar. Myslím, že to nevyzerá až tak zle, hoci sa snažím si prácu zjednodušovať, ako sa len dá :)
Upozorním len na to, že 1mm hrubé diely, na ktoré sa lepia bočnice treba v zadnej časti zabrúsiť do uhla - podľa obšívky.
Stavba tejto sekcie začína tu:
a končí tu:
mary
Příspěvek od mary »
Ahojki.
Hlásím, že je na světě kokpit a Halo, které jsem podlepil kartonem 0,5mm. Lépe se pak lepí boky na tupo.
A jak už jsem minule uvedl, že nejsem spokojen s napojení komínu, tak mi zapracovala fantazie,
a trošku jsem si ho upravil k obrazu svému modelářskému.
MatesHK
Tady jsem včera skončil. Na to, jak to na papíře a podle fotek vypadalo složitě, tak se to lepidlo dobře :)
mary
Příspěvek od mary »
Zatím všechno do sebe pasuje.
mary
Příspěvek od mary »
Začíná to vypadat jako formule. Zatím neslepeno.
Robert Blaschke
Parádne vám to ide všetkým. Poklona páni :)
Zpět na „Sport a F1“
